Void Coverage
Check the void coverage with hole placed to copper plane.
- Net Definition: Select net to check the hole area to copper plane. Usually, a Ground net will be defined. There are two ways to select the net: by Net Group or by Net Filter (naming rule of net).
- Layer Definition: Select the target layer.
- Option
- Maximum Copper Dimension for Excluding: Enter the maximum copper dimension value to be excluded from checking, which will be excluded if calculated ratio is less than the entered value.
- Hole Size Expanding: Enter the value to be used to expand the hole size.
Figure 1. - Hole/Copper Ratio(%): Enter the ratio value. If the calculated ratio is less than the entered value, it is considered a fail.
