The material library contains preset materials, as well as any custom materials
        you've saved. Understand the material library's structure so you can more easily find
        materials.
        Material Library Structure
                    - The Altair library contains preset materials.
                    - The User library contains any custom materials you've
                        saved.
The material library is structured as follows:
For example:
        Resize the Thumbnails
            Hover over the bottom of the dialog box to bring up the Preview
                    size slider. Drag the slider to zoom in or out.
