Define the Rendering Settings
Define the image resolution and select a rendering engine.
- On the ribbon, click the Rendering tab.
    Click the Camera/Rendering icon.
    Define the image resolution.
      On the Camera tab, do one of the following:
- Select from a list of Presets.
 - Enter a custom Width and Height. Tip:
- To maintain the aspect ratio, select Keep Aspect Ratio.
 - To swap the width and height, click the Swap button.
      Define the image quality:
- 360° Panoramic
 - Select this option to render a panoramic image.
    Define the rendering engine.
- On the Engine tab, select one of the following options:
- Raytracing: The standard rendering method, it simulates indirect lighting.
 - Presto/IR: The most efficient rendering method, which is
         always used for interactive rendering. You might use it to render simpler scenes that
         wouldn't benefit from a more powerful rendering method, or to create fast approximations of
         complex scenes.Note: Presto GPU support for macOS 10.14 (Mojave) and above is unavailable due to driver incompatibility. In this case, CPU is used.
 - Full (Progressive): The most accurate rendering method. It is particularly useful for rendering transparent objects (e.g., caustics and dispersion in gemstones).
 - Define the settings for the rendering engine.
