Select
Select and edit objects using the mouse and keyboard shortcuts.
You can select objects in the modeling window or Model Browser, before or after you activate a tool. The modeling window and the Model Browser are linked, so when an object is selected in one, it is automatically selected in the other.
| To | Do this | Note |
| Select an object | Click the object. | You can limit selection to a type of geometry by clicking
                                        one of the following icons at the bottom of the application
                                            window:
| Add to/remove from the selection | Hold down Ctrl while clicking the object. | When removing an object, click an edge of the object. |
| Select multiple objects | Box select the objects. | Drag from right to left to only select objects entirely within the box. |
| Select a range in a list | Hold down Shift while clicking the first object and the last object. | You can only do this in the Model Browser. |
| Deselect an object | Hold down Ctrl (Command) while clicking the object. | |
| Select all objects | Press Ctrl (Command) + A. | |
| Clear the selection | Click empty space. |
