Find and Search
Quickly search and find objects in your model.
Find
Find objects in the model that contain the search string you enter. The search results are not filtered.
In the Model Browser, click
to activate
the Find toolbar.
- Optional:
To control your search, click
then choose one or more of the
following options:
- Math Case
- Whole Name Only
- Use Wildcards
- In the text field, enter a search string.
- Navigate to the next and previous objects
that contain the search string by clicking
. - Find every object that contains the search
string by clicking
Search and Filter
Search objects and automatically filter the results to only display the objects that contain the search string. You can also filter by object type.
to
activate the Search and Filter toolbar.
- Optional:
following options:
- Math Case
- Whole Name Only
- Use Wildcards
- Optional:
Filter objects by type.
- Click the Filter pull-down menu and select the object types to filter.
- Click Apply.
