Automatic Computation mode
When automatic computation mode is set, inter bar end-ring impedances are computed by internal processes, being a function of the slip (or speed), the temperature at the end ring (at Connection Side and Opposite Connection Side), and the material of the end ring.
END RING – Automatic computation mode
1 Automatic computation mode selection
2 Impedance characteristic to be defined for which the impedances will be computed (optional)
3 Working point evaluation to be defined for which the impedances will be computed (optional)
