Save as
Save As and Save functions:
How to “Save As” a python Script ? | |
1 | Click on the dropdown menu select the function “Save As” |
2 | Click on the function “Save As” via the dropdown menu. |
3 | Give a name to the python script you want to save. |
4 | Select a working folder to store the new file (The default one is the current workspace). |
5 | A python file can be saved with the same name with the “Save” function. |
- To “Save” a file you can also use the classical shortcut keyboard “Ctrl+S”
- To “Save as” a file you can also use the classical shortcut keyboard “Ctrl+E”
