Settings
Four buttons give access to the following setting definition:
- Temperature of active components: winding and squirrel cage
Definition of the power electronics parameters
Inverter control strategy
Inputs for evaluating the power electronics stage losses
- Definition of mechanical loss model parameters
For more details, please refer to the document: MotorFactory_2022.3_IMSQ_IOR_3PH_Test_Introduction.
Import
Provides the ability to import the current inputs and results from the test “Characterization – Model – Motor – Scalar”. This will save the computation time related to the identification of the non-linear model, in other words, saves the computation time related to the finite element solving, which generally represent the main part of the computation time of the test.
| 1 | Import inputs – Accelerate test resolution |
| 2 | Current results from test “Characterization – Model – Motor – Scalar” |
