Learn about the definition, usage, and limitations of exposable
parameters.
Definition
When code is generated for a Super Block, for example to create a new block or export
an FMU, the OML variables used in the parameterization of the diagram inside the
Super Block can be considered fixed, in which case their numerical values are used
for the generation of the code, but they can also be considered exposable, in which
case their values can be modified even after code generation.
The exposable parameters of the Super Block can be used as block parameters of the
new block created by code generation, and the parameters of the exported FMU.
Selection
Designating a variable as an exposable parameter can be achieved in two ways: using
the OML exposable function or Super Block masking.
Selection using the exposable function
Using the exposable function explicitly is one way to define a parameter as
exposable. This is a simple way to define a parameter as exposable, anywhere
in the Super Block. For example, in the following Super Block, the Gain
parameter of the Gain block is defined as an
exposable parameter named A with the default value 3.
The parameter can also be defined in the Context of the diagram, as
follows:
A=exposable(‘A’,3)
and used to
define the Gain parameter value of the block. In this case, when code is
generated for the Super Block, the parameter A (the
gain value) is exposed. The second argument of the
exposable function defines the default value of
the parameter.
The exposing of the parameter A
and its default value is possible for example by using any of the code
generators to create a CCustomBlock or generate the
FMU of the Super Block:
The exposable parameters are defined primarily for code generation
purposes but defining them explicitly using the
exposable function affects the simulation of the
model as well. Particularly, if a variable with the same name exists in
the OML base environment, then the exposed parameter takes the value of
this variable for Model Evaluation. So, in the above example, if a
variable A is defined having a value of
4 in the OML base environment, then the
simulation uses the value 4 for parameter A.
If
A is not defined in the OML base, then the
simulation runs normally as if A were not exposed
(with value 3). The exposable function behaves like
the GetFromBase function during the Model Evaluation
phase.
This way of designating a parameter as exposable is useful
in some cases, for example when a deep level parameter is to be made
exposable without having to modify the model, but in most cases, it is
not the most convenient way of defining exposable parameters. The
natural way to select exposable parameters is to mask the Super Block
(by auto-masking for example), specifying the variables used but not
defined inside the Super Block, and then use these variables to select
the exposable parameters.
Selection by masking
For an unmasked Super Block, no diagram parameter is considered exposable
(other than any explicitly defined using the
exposable function, as presented previously).
This is the case even if a variable used inside the Super Block is
defined outside the Super Block. But in this latter case, if the block
is auto-masked, the variable becomes a mask parameter, and it can then
be defined as an exposed parameter if desired.
Consider the following model where the variable A is
defined in the Model Initialization script and is used inside the Super
Block (to define the parameter value of the Gain
block). If the Super Block is not masked, no parameter is exposed and
the generated code for the Super Block uses the numerical value of
A=1. It would be the same as if the value of the
parameter of the Gain block was set to 1.
The variable A in this case is not defined as an exposable parameter even
though it becomes a mask parameter if the Super Block is auto-masked
(the auto-masking operation identifies the variables used inside and
defined outside the Super Block, in this case A), as shown here:
Masking the Super Block is a way to define exposable parameters. In
particular, when code is generated for a masked Super Block, all the
variables used in the definition of the values of mask parameters are
defined as exposable parameters. Note that if the masking is done using
the auto-masking operation, the variables correspond exactly to the mask
parameters. But the expressions defining the values of the mask
parameters may contain any variables defined outside the Super
Block.
Consider the model shown in the previous figure. The Super Block mask
parameter is A, and so is its value. In code
generation for this Super Block, A is considered
exposable, and its default value is taken to be 1. Note that A is
considered exposable because the value of the mask parameter is defined
as A and not because of the name of the mask
parameter, which also happens to be A and corresponds
to a local variable of the Super Block. So, if the value of the mask
parameter A is defined numerically, as shown next,
prior to code generation:
then A is not exposed when the code is
generated for the Super Block.
In the following example, on the other hand, where the parameter value of
A is defined as a function of other variables (B and
C in particular):
the exposed parameters are B and
C (these variables must be defined outside the
Super Block for the model to be correct). B and
C become the parameters of the new block obtained
by generating code for the Super Block:
Note that A is not exposable in this case; it is
simply a local variable of the Super Block.
The two methods for defining exposable parameters (via Super Block mask
parameters and the explicit use of the exposable
function) can be used simultaneously for the same diagram. The resulting
exposed parameters then include both the parameters exposed by masking
and the use of the exposable function.
Classical Inverted Pendulum on a
Cart
Consider the problem of the classical inverted pendulum on a cart.
The system state contains the position and speed of the cart, and the angle and
angular velocity of the pendulum. State feedback control is used to stabilize the
pendulum in the vertical upright position. The model contains a delay block for
studying the effect of control delay in the performance of the controller:
The model of the Pendulum dynamics is placed inside a Super Block. Here various
code generation methods are applied to this Super Block, illustrating how the
methods work and differ.
The Super Block has one input (force applied to the
cart) and one output (vector containing all four elements of the state). The parameters
used inside, and defined outside, are the cart and pendulum masses,
M, m, the pendulum length, l,
its moment of inertia, J, the initial state x0 (the
initial state of the Integrator block) and the gravity constant g.
These parameters can be seen by auto-masking the Super Block:
The Super Block can now be used like a regular block, with the mask as the
parameter GUI. This GUI can be customized by editing the mask as follows:
Code Generation
The application of code generation to this Super Block, as discussed
earlier, exposes all the mask parameters because their values are
defined as variables with the same names. The application of the code
generators produces a C Custom block with opar parameters
x0, J, M,
g, l and m,
as shown here in the case of the standard code generator:
The C Custom block is placed automatically in a masked Super Block with
the same parameters.
Selection of Exposable Parameters to Expose
Parameters that you would want to expose are not necessarily exactly the
parameters obtained by masking the Super Block. For example, in the
cart-pendulum system, the more natural set of parameters to expose are
m, M, l and
the initial positions. The moment of inertia is a function of the
pendulum mass and length (J=ml2/12) and g=9.81.
The full initial state is also often not required; only the initial
system positions (cart position and pendulum angles), z0 =
x0(1) and θ0 = x0
(3), are considered. To use these as exposed parameters, the
mask parameter values of the original system can be modified as
follows:
Note that the initial velocities are set to zero.
After defining initial values for z0 (z0) and
θ0(th0), for example in the Model
Initialization script, the application of code generation, as expected,
results in the following set of exposed parameters (the values of the
exposed parameters here are manually replaced by numerical values):
Similarly, if the Super Block is used to export an FMU, the exported FMU
will have the same parameters:
Limitations with Exposable Parameters
Exposable parameters of a Super Block can be used directly in expressions defining
the values of the parameters of the blocks inside the diagram of the Super Block or
be used in the Super Block Context to define other variables used as such. There are
however limitations in the usage of exposable parameters.
Exposable parameters can be used in OML expressions involving basic operators
(addition, subtraction, multiplication…), matrix extraction and concatenation, and
basic math and trigonometric functions. These functions are overloaded to accept
exposable parameters. Since the implementation uses operator overloading,
expressions including calls to functions including basic operators and overloaded
functions are also supported. However, exposable parameters cannot be used in
non-overloaded built-in functions. For example, in the implementation of a Chebyshev
filter block where the block parameters are computed using the OML built-in function
cheby1, the parameters of the mask (filter parameters) cannot
be exposed because cheby1 is not overloaded.
Even if an expression involving exposable parameters is valid, it cannot necessarily
be used for the definition of all block parameter values. The reason is that not all
block parameters in Activate libraries accept expressions with exposable parameters.
Structural block parameters are clearly excluded, and so are any parameters that
affect the size or type of signals. Other block parameters, for the most part,
accept expressions with exposable parameters. The list of block parameters that
support the use of exposable parameters is provided below.
List of Block Parameters that You Can Expose
The following Activate block parameters support expression with exposable
parameters:
Activate Block
Accumulator
x0
Bias
B
CompareToConstant
C
ConditionalSelect
Thra
Constant
C
ContStateSpace
x0
ContTransFunc
Num, den
Counter
Minim, step
Deadzone
lower, upper
DFlipFlop
init
DLatch
init
DiscreteDelay
init_cond, maxim, Initv
DiscreteIntegral
x0
DiscrTransFunc
num, den
EventDelay
delay
EventGenerate
etimes.time{1}
FixedDelay
T
Gain
gain
Horner
coeffs
Integral
x0
JKFlipFlop
init
LookupTable
xx, yy
LookupTable2D
xx, yy, zz
LookupTableND
Ff, dimi{i}
MatrixGain
gain
MathExpression
All parameters used in the expression
MatrixExpression
ModuloCounter
ini_state, base, step
Power
power
PID
Kp, Ki, Kd
Ramp
slope, startt, initout
RampSaturate
Height, duration, offset, startTime
Random
A, B
Saturation
upper, lower
Sawtooth
Period, up, down
SignalGenerator
xx, yy (only scalar double signals, without output
derivatives)
OML Operators and Functions that You Can Apply to Exposable Parameters
Exposable parameters can be used in the computation of the values of exposable block
parameters. This computation can be limited to an OML expression or based on the
execution of one or more scripts included in Super Block Contexts. Even though there
is no explicit limit on the complexity of the resulting expression, the usage should
be limited to “simple” expressions; complex expressions may not be efficient to
evaluate and may even fail.
Exposable parameters, and other variables depending on exposable parameters, can be
matrices of arbitrary sizes. Their usage is supported for the following operators
and functions:
Basic operators:
Matrix row and column concatenations, and matrix extraction (with access via ‘:’
and ‘end’ supported)
Primitive functions returning numeric values: size, length, isvector,
isscalar, issquare. Since the sizes of exposable parameters are fixed
and do not depend on their values, the output of these functions can be
determined at compile time.
Any OML function that uses only the above operators and functions within its
definition, or other OML functions of the same type.
Suppose X and Y are exposable parameters, then the following
expressions and instructions are valid:
X + Y
Z = X .* Y; sin(Z)^2
X(1,:) * X(:,1)
Z = [X, Y]; Z’
if isscalar(X), Z=X; else Z=Y; end
The last statement is valid because at compile time, it is known whether X is
scalar or not based on its default value.
The following expressions and instructions are not valid:
eig(X)
eye(X,Y)
if X > 0, Z = X; else Z=0; end
The last statement however can be expressed as an equivalent valid expression as
follows:
