When running an analysis, automatically export your model and perform advanced
meshing in SimLab.
Prerequisite: You must have SimLab installed for this
feature to work.
Click Run Analysis on the Analyze icon.
On the Advanced tab, select Use advanced meshing with
SimLab.
Click the Run button. As part of the analysis, SimLab
will be launched and your model automatically imported.
In SimLab, select the Casting tab.
Use the Mesh Controls, Surface
Mesh, and Volume Mesh tools to perform
advanced meshing.
When finished meshing, select the Save and Exit icon on
the ribbon.
Your model will be exported back to Inspire Cast, and the
analysis will resume.
