Sharpen
Use the Sharpen tool to control sharpness along the edges of a PolyNURBS. Four levels of sharpness are available, and you can set the sharpening factor manually or automatically.
- Select Auto Sharpen on the microdialog to automatically determine the sharpening factor.
- Select a sharpening level in the legend to hide the edge coloring for that level of sharpness.
- High sharpening produces perfect creasing. You can add fillets or chamfers to edges with high sharpening.
