Response Files
Introduction
A response file is an installer properties file used to provide properties for an installer running in silent mode. The files contain text in a simple VARIABLE=VALUE format.
Response files
The properties in the response files are captured by executing the installer and the captured variables are then used as default values for future silent installs. The installer automatically checks the same directory as the installer for a file called installer.properties to use as input to the installer.
An example of a response file containing properties:
#Accept License Agreement
ACCEPT_EULA=YES
#Choose Install Folder
USER_INSTALL_DIR=C:\\Program Files\\Altair\\2022.3
#Change Shortcut Folder (Local)
SET_START_MENU_FOLDER=Altair 2022.3
INSTALL_DESKTOP_SHORTCUTS=0
#Enter License Path Location
FLUX_ALTAIR_LICENSE_PATH=6200@server.domain
FLUXMOTOR_ALTAIR_LICENSE_PATH=6200@server.domain
Note: Spaces should not be used between VARIABLE=VALUE statements in the response file.
