PBS Flux Examples
Here are some Flux examples directly ready to be run via PBS.
2D examples
Example | Documents | Illustration |
Magneto Static application - Sensor |
With one Flux File and python files to drive the solving and postprocessing process
With one python file to drive the construction of the geometry, the physic setting, the solving and postprocessing process
With multiple python files to drive the construction of the geometry, the physic setting, the solving and postprocessing process
With one Flux File. In this case we will solve the existing scenarios (no postprocessing) |
3D examples
Linear Actuator |
With multiple python files to drive the construction of the geometry, the physic setting, the solving and postprocessing process With one Flux File. In this case we will solve the existing scenarios (no postprocessing) |
