Dye Regions
Used for fluid motion tracking.
- Dye regions can only be spherical in shape.
- If a particle passes through multiple dye regions, it will adopt the color of the last dye region through which it passed.
Commands
dyeRegions
dyeRegion
dyeregion_clr 1
dyeregion_cntr "0.0 0.1 0.2"
dyeregion_rad 0.1
dyeregion_radodx 2.5
dyeregion_tstart 0.0
dyeregion_tend 1.0
| Command | Contents | SI Unit Example |
| dyeregion_clr | Color assigned to the dye region. | |
| dyeregion_cntr | Center coordinates of the dye region sphere. | |
| dyeregion_rad | Radius of the dye region sphere. | [m] |
| dyeregion_radodx | Radius of the dye region sphere as a function of dx, for example,
when specified 3.0, implies 3.0*dx. Note: If both
dyeregion_rad and
dyeregion_radodx are present, the latter
takes precedence.
| dyeregion_tstart | Start time of dye injection. | |
| dyeregion_tend | End time of dye injection. |
