Load Balancing
The dynamic load-balancing (LB) capability allows the nanoFluidX code to redistribute the work load among the GPUs, which generally improves the overall performance.
loadbalancingParameters
type DYNAMIC
frequency 100
imbalance_tol 1.1
}- type
- Type of load balancing.
- frequency
- This parameter specifies the frequency at which the workload will be redistributed among the GPUs. The frequency is expressed in time steps, so a number of 100 sets the redistribution every 100 time steps. This value can cause computational overhead if set to very low values. Keep the default value of 100 time steps, or at least that order of magnitude.
- imbalance_tol
- This parameter specifies the workload tolerance discrepancy between the GPUs. The default value of 1.1 implies that the work load redistribution will be carried out among two GPUs only if the work load that they are handling differs by more than 10 percent.
Overall, the parameters for the LB are best kept at their default values, once the LB is turned on, as poor choice of the above parameters can actually detriment the run time of the simulation.
