Enable the nanoFluidX Toolbar Plugin
In the nanoFluidX installation folder you will find the PV_nFX_aux folder containing three additional folders: PV_backgrounds, PV_materials, and PVnFXTools. The ParaView nanoFluidX toolbar is in PVnFXTools folder.
- Threshold
- Slice
- Clip
- Streamlines
- Tube
- Glyph
- Contour
- Calculator
- Transform
- SPH Line Interpolator
- SPH Surface Interpolator
- SPH Volume Interpolator
- Plot Data
- Iso-volume
- Surface Vectors
- Extract Time Steps
- Temporal Statistics
- Plot Selection Over Time
- Compute Derivatives
- Integrate Variables
- Descriptive Statistics
- Probe Location
- SPH Dataset Interpolator
- Resample with Dataset
- Table to Points
- Extract Selection
- Programmable Filter
The majority of post-processing can be done with essential set of nanoFluidX tools. The extra tools are intended only for corner case post-processing requirements.
