License Environment Variable Setting
The environment variable ALTAIR_LICENSE_PATH is used to point to the license file or server.
ALTAIR_LICENSE_PATH must point to a valid local license file or to a network license server in the form of port@servername, for example, 6200@licsrver.
In the past, the environment variable was either LM_LICENSE_FILE or ALTAIR_LM_LICENSE_FILE.
