| Note: | To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel. |
| 1. | From the Menu Bar, select Connections > Glue > Modify. |
| 2. | Select only one glue (see Glue Selection for more information). |
| 3. | Click |
| • | In the Part sub-window: |
Button |
Behavior |
displays all the parts in the neighborhood of the selected glue. |
pick parts in the graphic window to add them to the glue definition. |
select parts by box in the graphic window to add them to the glue definition. |
adds the selected parts of the tree in the glue definition |
deselects the parts that define the glue |
| • | In the Location sub-window, it is possible to change the glue location. (See element, node, or line for more information). |
| • | In the Property sub-window: |
| - | Click Prop. Name and select a property (beam type spring property - type 13) in the common property database. |
| - | Enter the name of the HyperCrash property file (beam type spring property - type 13). |
| 4. | Click Save to save the modified glue; or |
Click Cancel to cancel the glue modification.
| 5. | Click Close to close the menu. |
Button |
Behavior |
select all the glues. |
select all the uncreated glues. |
pick glues in the graphic window to select them. |
select glues by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the glues linked to those parts. |
select parts by box (use the SHIFT key to use a polygon box) to select all the glues linked to those parts. |
Click on the glue line in the listing window to select it. Several glues from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
automatically recreate the "uncreated" glues. In the message window, a message explains why this glue cannot be created. |
