Other Methods for Fitting a Curve The following methods require certain parameters other than UTS to define the SN/EN curve. From the Assign Material dialog, click the My Material tab and select your created material. For Number of SN curves, select Single. For Curve Type, select Ratio/ Haigh Diagram. Select an input method. Click to view the model description. Define any necessary parameters. Note: The images below use the default values as a guideline. SN Properties Figure 1. Point, 1-seg Figure 2. Figure 3. Point, 2-seg Figure 4. Figure 5. Slope-intcept, 1-seg Figure 6. Figure 7. Slope-intcept, 2-seg Figure 8. Figure 9. Slope-trans, 1-seg Figure 10. Figure 11. Slope-trans, 2-seg Figure 12. SN Properties in XY Format Figure 13. XY Data SN Curve Figure 14. Format of SN Curve in XY Data Single Haigh Diagram Figure 15. Single Haigh Diagram Figure 16. Format of Haigh Diagram CSV EN Properties Figure 17. Slope Figure 18.
