Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
The HyperWorks Material Library is a database that stores engineering material information to ensure that material properties used
in simulations are up to date and accurate, and provides standardization of material data across an organization.
You can create a material library, either local or shared, similar to the way you create a part library. A local library resides on your computer, and a shared library resides on another computer.
Adding an existing material library is useful when another user has already created a shared library and you would
like to access it. The steps are essentially the same as creating a new library, but instead of selecting an empty
folder, you should instead select a folder that already contains a material library.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and
text that have HyperMesh-supplied and user-defined macros associated with them.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
shared library and you would like to access it. The steps are essentially the same as
creating a new library, but instead of selecting an empty folder, you should instead select
In the Model Browser, click the Materials
View icon () on the toolbar.
All materials in the current model file display.
In an empty area of the browser window, right-click and select Library > Libraries... from the context menu.
The Libraries Manager dialog opens. Figure 1.
Click the plus sign (+).
In the Library type field, select the type of library that matches the library
you want to add.
Note: If a library will have multiple simultaneous users, a shared library is
recommended.
In the Library path field, select the folder in which the material library
resides. The library name will automatically display.
Click Add.
The new library is added to the list of libraries.
Click the new library in the library list, and then click
Connect.
You will be connected to the new material library.
