Material Library
The HyperWorks Material Library is a database that stores engineering material information to ensure that material properties used in simulations are up to date and accurate, and provides standardization of material data across an organization.
Material Library provides rapid access to material information required by analysts which can be loaded into a session to aid with simulation setup. The material library can store information on all material attributes for multiple solvers at a time. Information can be seamlessly imported into HyperMesh, eliminating the need to locate required information and removing errors associated with manually entering data.
