hwIDataFile GetHashValue
Finds the hash value (sum of the structure of the file).
hwIDataFile_handle GetHashValue
HyperWorks Tcl Query
This command returns the hash value of the file (based on its structure). The command finds the checksum of the structure of the file, making the hash value, which allows you to compare to other data files hash values. You can then check if the two structures are the same.
hwi GetSessionHandle sess;
sess GetDataFileHandle df c:/demos/mv_hv_hg/plotting.adams/wiper.req;
df GetHashValue
      Error
Success (the hash value) or an error message is returned.
Keywords
HyperWorks
XY plot
Tcl
import
query
