hwIDataFile SetFilename
Sets the current file in the data file handle.
hwIDataFile_handle SetFilename filename
HyperWorks Tcl Modify
This command sets the current file being used in the data file handle.
- filename
 - The file path of the desired file. If the file path has spaces in it, the input must be within quotation marks, " ", or curly braces, {}.
hwi GetSessionHandle sess;
sess GetDataFileHandle df c:/demos/mv_hv_hg/plotting.adams/wiper.req;
df SetFilename C:\demos\test.abf
      Error
Success (a true or false value) or an error message is returned.
Keywords
HyperWorks
Tcl
Data File
Query
