hwIPage GetWindowSyncGroupItemList
Gets a list of window IDs in the synchronization group.
hwIPage_handle GetWindowSyncGroupItemList syncGroupName
HyperWorks Tcl Query
This command returns a list of window IDs in the synchronization group.
- syncGroupName
 - Give your window synchronization group a meaningful name, or an ongoing number (for example: HW-SyncGroup1, SyncGroupModelBracket, or Page 1).
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle pg [proj GetActivePage]
set numberOfWindows [pg GetNumberOfWindows]
set windowIdList ""
for { set i 1} { $i <= $numberOfWindows } { incr i } {
    lappend windowIdList $i
if { [string length $windowIdList] } {
    set syncGroupName "MyWindowSyncGroup"
    pg AddWindowSyncGroup $syncGroupName $windowIdList
    pgr SetWindowSyncGroupState $syncGroupName true; #activate window synchronization on this group
    puts "Windows in synchronization group $syncGroupName : [pg GetWindowSyncGroupItemList $syncGroupName]"
}Errors
None.
