hwIPage SetAnimationFrameRateTracking
Enables the animation frame rate tracker.
hwIPage_handle SetAnimationFrameRatesTracking enable
HyperWorks Tcl Modify
This command determines whether the animation frame rate tracker is enabled.
- enable
- True
 - If you want the animation frame rate tracker to be on.
 - false
 - If you do not want the frame rate tracker on.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 SetAnimationFrameRatesTracking true;
      Error
Keywords
HyperWorks
Tcl
Animation
Modify
