hwIWindow Draw
Draws the client object.
hwIWindow_handle Draw
HyperWorks Tcl Query
Error
Success (0) or an error code.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Returns the client object handle.
Returns the window client type.
Gets the height of the graphics window.
Gets the width of the graphics window.
Gets the window caption used when exporting to HTML.
Returns the window ID.
Returns the offset of a given window.
Returns the scale of a given window.
Returns the view control handle for the current client.
Gets the export file type for hwlSession_handle PublishSession.
Tests if the window is empty.
Sets the window client type.
Sets the window caption used when exporting to HTML.
Sets the offset of a given window.
Sets the scale of a given window.
Sets the export file type for hwlSession_handle PublishSession.
ON THIS PAGE
ON THIS PAGE
