hwIWindow SetHTMLCaption
Sets the window caption used when exporting to HTML.
hwIWindow_handle SetHTMLCaption caption
HyperWorks Tcl Modify
This parameter is used during HTML export.
- caption
 - The caption of the window in the HTML report.
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage GetWindowHandle myWindow 1
myWindow SetHTMLCaption "First Test"Errors
Success (0) or an error code (see below).
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
