plt3DIWaterfall CopySlice
Copies a waterfall slice to the clipboard.
plt3DIWaterfall_handle CopySlice index
HyperWorks Tcl Query
All waterfalls share a single clipboard, which can contain (in theory) one or more slices. The current implementation limits the number of slices that can be on the clipboard at a time to one (or zero). Copying a new slice to the clipboard will erase a slice previously stored there.
index
The index of the slice to copy (one-based).
To copy a slice from an existing waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName CopySlice 1
None.
