plt3DIWaterfall GetHighlighted
Returns the curve’s highlight state.
plt3DIWaterfall_handle GetHighlighted
HyperWorks Tcl Query
- True
- The curve is visible.
- False
- The curve is not visible.
None.
View new features for HyperWorks Desktop 2022.3.
Automate common workflows using the Process Manager.
Adds a new cursor on a waterfall.
Adds a new slice to a waterfall.
Copies a waterfall slice to the clipboard.
Gets the color of the waterfall.
Gets the handle of a cursor on the waterfall.
Gets the handle of a particular data source from the waterfall.
Gets whether or not the curve is displayed in the legend.
Gets whether waterfall is visible.
Gets the color of mesh lines superimposed on the waterfall.
Returns the curve’s mesh mode.
Gets a named meta-data value previously associated with the waterfall.
Gets the current number of slices in the waterfall.
Gets the current number of curves on the curve clipboard.
Gets whether a waterfall’s X, Y, and Z vectors are parameterized by U and V vectors.
Returns the curve’s polygon mode.
Gets the handle of a particular slice of the waterfall.
Gets the curve’s visibility state.
Pastes a waterfall slice from the clipboard.
Removes a cursor from a waterfall.
Removes a slice from a waterfall.
Sets the color of the waterfall.
Sets whether or not the curve is displayed in the legend.
Sets whether the waterfall is visible.
Sets the color of mesh lines superimposed on the waterfall.
Associates a named meta-data value with the waterfall.
Sets the curve’s mesh mode.
Sets whether a waterfall’s X, Y, and Z vectors are parameterized by U and V vectors.
Sets the curve’s polygon mode.
Sets the auto curve visibility state.
Converts a waterfall based on individual slices into one based on matrices.
None.
