pltIPlotManager GetUseEvenCycles
Determines the state of the Use Even Cycles option.
pltIPlotManager_handle GetUseEvenCycles state
HyperWorks Tcl Modify
This command determines if the Use Even Cycles option is on or off. If on, Use Even Cycles makes even cycles when fitting the log axes. The command returns a true or false value. If true is returned, Use Even Cycles is on. If false is returned, Use Even Cycles is off.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetUseEvenCycles;
Keywords
HyperWorks
Tcl
Modify
