pltIPlotManager SetUseEvenCycles
Sets the state of the Use Even Cycles option.
pltIPlotManager_handle SetUseEvenCycles state
HyperWorks Tcl Modify
This command sets if Use Even Cycles is on or off. If on, Use Even Cycles makes even cycles when fitting the log axes.
- state
 - A true or false value.
- True
 - When you want Use Even Cycles to be on.
 - false
 - When you want the option to be off.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm SetUseEvenCycles true;
Keywords
HyperWorks
Tcl
Modify
