poIPostManager RemoveModel
Removes the given model from the master model table. The model is only removed if there are no other references to that model.
poIPostManager_handle RemoveModel modelid
HyperView Tcl Modify
This command removes the given model from the master model table. The model is only removed if there are no other references to that model.
- modelid
 - The model ID.
Returns 0 if successful, otherwise an error code.
