poIPostManager SetMemoryWarningThreshold
Sets the memory warning threshold value.
poIPostManager_handle SetMemoryWarningThreshold threshold
HyperView Tcl Modify
This command, valid only in Upfront Data Loading Mode, sets the current memory warning threshold value. This value is a percentage from 0-100 which represents a percentage of the total system memory. If the total system memory exceeds this threshold and the memory warning feature is enabled, a warning will trigger.
- threshold
 - The memory warning threshold percentage value from 0-100.
To set the current memory warning threshold to 75%:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr SetMemoryWarningThreshold 75
hwi CloseStack
None.
See the Upfront Data Loader APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
