vidIVideo SetMeasureType
Sets the type of measure.
vidIVideo_handle SetMeasureType id type
HyperWorks Tcl Modify
Sets the type of measure. Valid types of measures are master, static, and dynamic. Master is the master measure for a given video which provides units and a conversion factor between pixels and units. It cannot be added or deleted. Other types may be set to a given measure and are described below.
- id
 - The ID of the measure to be modified.
 - type
- dynamic
 - A measure between two tracing markers which is valid for the time range in which both markers exist together.
 - persistent
 - A pixel-to-pixel measure which is the same for all time steps. Also called as a static measure.
 - transient
 - A pixel-to-pixel static measure with the ‘at the time of creation’ option turned on, meaning this measure is shown only at the time step at which it was created.
// Load a suitable video in the MediaView window:
hwi OpenStack
hwi GetActiveClientHandle v
v AddTracingMarker
v AddMeasure static
v GetMeasureHandle m2 2
m2 SetMeasurePoint1X 300
m2 SetMeasurePoint1Y 300
m2 SetMeasurePoint2X 400
m2 SetMeasurePoint2Y 500
m2 SetShowMagnitude true
v GetTracingMarkerHandle mark1 1
mark1 SetTrackPoint 270 186
v GetTracingMarkerHandle mark2 2
mark2 SetTrackPoint 466 291
v SetMeasureType 2 dynamic
m2 SetMarker1 "Marker:0"
m2 SetMarker2 "Marker:1"
v Draw true
Returns success or an error code.
Keywords
- HyperWorks
 - MediaView
 - Tracing
 - Tracking System
 - Measures
