Define Interface
Use the Define Interface tool to create, import, and edit geometric lines.
- Create 3D lines
- Import geometry file
- Edit 3D lines
Create 3D Lines
Create 3D lines on the component edges.
- Fast create: SnRD automatically creates geometric lines on the edges of the selected components.
- Manual create: Create 3D lines along the required node path. This requires manual inputs and provides more control over line creation.
Manually Create Geometric Lines
Switch to Manual mode, when there is a need to create geometric lines with more precision and control.
Import Geometry File
Import a geometry lines definition file.
to define feature options and control
Geometrical Lines creation.
to define controlled line creation.
