Solver Execution
To select or change the analysis settings for a solver run, click the Analysis
settings dialog satellite icon
that appears when you
hover over the Run tool. After making your selections, click the Run
button to submit the model to the solver.
MotionView communicates with MotionSolve through an internal process to provide live animation and status updates as the solution progresses.
Execute Solvers
MotionView allows you to save the solver input deck and invoke the solver in one step. To do this, a script (or .bat file on PC) must be registered in the preferences_mbd.mvw file available in the HyperWorks installation at ~altair_install/hw/prefinc. Use the *RegisterSolverScript() preference statement to register the solver script. When registered, the solver script can be executed by clicking Run in the Run Solver panel.
MotionSolve
MotionSolve has two pre-registered invoke scripts. The MotionSolve script is used to submit runs to MotionSolve from MotionView. The other script, MotionSolve_HST, can be used while using HyperWorks with HyperStudy (a general optimization software).
The solver input deck format for MotionSolve is XML. For more information on MotionSolve and XML format, refer to the MotionSolve Reference Guide.
Other Solvers
For other third party solvers like ADAMS, the MotionView installation contains scripts that require you to edit them only once before using. These can be found in the <ALTAIR_HOME>\utility\mbd\launch_scripts\ directory.
MotionView exports to the following ADAMS solver input deck format: ADM/ACF.
