Define Mesh Controls
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
View new features for HyperWorks 2022.3.
Define meshing preferences.
Set the appropriate parameters/options to obtain the desired mesh by editing the criteria and parameter files.
Mesh controls are used to automate and streamline the meshing process.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Setup an Optimization in HyperWorks.
ON THIS PAGE
ON THIS PAGE
