PM Flex Tire
                                 This tire is a FE based flexible tire solution from Pratt Miller that can interact with     EDEM particles representing soil,
                                    sand, gravel, and so on. The tire model requires a finite     element modeling file (.bdf) and other associated files. The AutoTire     entity in MotionView provides a utility to generate the required     mesh files from a CAD file. The tire can then be transferred to EDEM through
                                    MotionView-EDEM coupling interface. PM-FlexTire software is available as an       Altair Partner product under the Altair Units licensing system.
