Evaluate
Use the Evaluate tools to run the exploration and review reports.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints.
An input design variable is a system parameter that influences the system performance in the chosen output response. Typical design variables may be a part's thickness, shape, or material property. Ranges, with lower and upper bounds, are specified and the variable's value will vary within the exploration. The terms input, input design variable, and design variable are used interchangeably.
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Objectives are metrics to be minimized or maximized in an optimization exploration. Minimizing mass to find a lightweight design is a common example.
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Review the explorations, inputs, responses, and goals in your design setup.
Export files to the output directory then run the exploration simulations.
Stop a simulation and cancel any runs that are pending or in progress.
Use the Results Explorer tool to review results.
ON THIS PAGE
ON THIS PAGE
