View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
Use the floating Entity Editor to edit attributes for plot entities.
Use the entity selector to specify the plot entity to select.
Use the View toolbar to control the view and display of your plot, the curve color display, and plot curves instantly.
Set default parameters for HyperGraph plot types.
From the HyperGraph modeling window, right-click to display HyperGraph context menus.
Axis attributes, such as labels, color, and scaling, can be edited using the Plot Browser, Entity Editor, or the Axes right-click context menu.
Using the Convert Axis Units dialog, you can convert the current unit of measure of a horizontal or vertical axis to another unit of measure.
The Synchronize Windows feature allows you to manipulate multiple plots in multiple windows at the same time.
ON THIS PAGE
ON THIS PAGE
