Select a Range of Curves
- From the HyperGraph 3D Curve Attributes panel, select a curve from the Curves list.
 - Drag the pointer to include the curves above or below the selected curve.
Or
- Select a curve from the list.
                Hold down the Shift key and select another curve from
                    the Curves list.
                The range of curve names between the first and second selections is highlighted.
