Use a File as a Data Source
- From the Bar Chart Define panel, select .
Click the file browser button,
, and select a data file.
- Select a vector data source by specifying the Type, Request, and Component.
- Click Apply.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
ON THIS PAGE
ON THIS PAGE
