Legends View
The Legends view, ,
displays only the legends in the session, grouped within their respective page and
plot folders. Click Legend to display the legend's properties in the Entity Editor.
![](../../images/hypergraph/plot_browser_legend_view_hgx.png)
The following legend properties are visible and editable through the Entity Editor.
Standard
- Visibility
- Click the check box to display the legend; leave it blank to turn off the legend from the graphics window.
- Auto Positioning
- Automatically positions the legend withing the modeling window.
- Legend Placement
- Click to display the drop-down menu and select the legend's placement in
the modeling window. Options include:
- Inside-Left-Top corner
- Inside-Left-Bottom corner
- Inside-Right-Top corner
- Inside-Right-Bottom corner
- Outside-Top
- Outside-Bottom
- Outside-Left
- Outside-Right
- Inside-User defined. Use the X Coordinate and Y Coordinate fields to enter specific coordinates for legend placement in the modeling window.
Display
- Border Style
- Click to display the drop-down menu and select a line style for the legend's border.
- Border Color
- Click to display the drop-down menu and select a color for the legend's border.
- Font Settings
- Click on the current font settings to display the Font Selector dialog. From the dialog, you can select the font type, style, and size.
- Leader Position
- Select from Left or Below for the leader position.
- Background Fill Color
- Select Default or User Defined.
- Curve Text Color
- Select Curve Color or User Defined.
