Offset Curves Along the Phase Axis
- From the Complex plot toolbar, select the Scales, Offsets, and Axis Assignments panel.
 - Select the curves from the list or pick them from the window.
 - Turn on the YP offset check box and enter the distance to shift the curves in the text box.
                Click Apply to accept the new scaling values.
                The data is shifted to the right for positive values and to the left for negative values.
