Use Math as a Data Source
- From the Define panel, under Source, select Math.
 - Define the vector using the curve calculator to create a mathematical expression.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
