Root Mean Square Deviation
Calculates the RMS difference value between a give expression and a desired curve.
![](../../images/post_processing/optimization_wizard_response_types_root_mean_sqr_dev_panel.png)
Figure 1. Response Type – Root Mean Square Deviation
Input | Description |
Desired Curve | Choose existing curve from the model using the Curve collector to define the desired behavior. |
Response Expression | A function that is computed during the run and RMS difference is calculated between this function and the Desired Curve. |
Specify independent variable | Turn ON this check box to use a solver variable as an independent variable for both Desired Curve and Response Expression. When OFF; by default, Time is used as independent variable. |
The Show desired curve… button can be used to plot the Desired Curve on graph.
In the above example, the response variable computes the root mean square deviation between a marker’s X displacement and the desired displacement profile defined by the curve “X-Vals”.
