Points
Use the Points tool to create and edit individual points, points on a vector, points along a curve, points at the center of a circle, and parametric points.
A Point is a spatial entity defined in a Global Cartesian space. Other entities that need a location or orientation can also refer to a point entity.
A Point entity can be defined as a single or pair. The Pair entities help in creating models which are symmetric about the Z-X Plane of the model. Their properties can also be symmetric about the Z-X Plane (in other words, the Y property is mirrored).
Create Points using the Points Tool Set ![](../../images/icons/icon_points_geom_ribbon.png)
Use the Points tool set in the Geometry ribbon to create points using the methods described below:
Create Points through Graphical Interaction
Add a point to the model with the Points tool.
![](../../images/icons/icon_model_sm_mvx.png)
![](../../images/icons/icon_system_sm_mvx.png)
![](../../images/icons/icon_analysis_sm_mvx.png)
![](../../images/icons/icon_point_sm_mvx.png)
Create Points on a Vector
Use the Create Points on a Vector tool to create a set of points along a vector.
Create Points Along a Curve
Use this option to create a set of points equally spaced along a curve.
Create Points at At Arc Center
Use this option to create points at the center of an arc.
Create Parametric Points
Use the Parametric Points dialog to create a set of points with respect to a reference marker either in Cartesian coordinates or cylindrical coordinates.
Edit Points
Change the coordinates of a point.
Point Properties
Property | Description |
General | |
Label | Descriptive label for the entity |
Varname | Variable name of the entity |
ID | Integer identifier |
Active | Active state of the entity (True or False). Entity is deactivated if False. |
Properties | |
X | X coordinate in Global Frame |
Y | Y coordinate in Global Frame |
Z | Z coordinate in Global Frame |
Appearance | |
Visible | Visibility state of the entity |
Notes and Tags | |
Notes | Optional descriptive note |
Attachment Candidates | Use to declare the entity as candidates to be used as attachments. |
Point Pair Properties
Each side of the point pair (Left and Right) have properties as listed in the above table. The following are the additional properties for a point pair: | |
Symmetry | Indicates the side that is the leader. Available choices are:
- A point is used in other entities such as joints, bushings, spring dampers, user defined cg for body, and so on to position or orient the entity.
- A symmetric point pair is symmetric about the Global Z – X plane.
- The point does not have an equivalent representation in MotionSolve xml.
