Using H3D Flexbodies in MotionView
                Select a body in the modeling window or the Model Browser.
                The Bodies panel is displayed.
 - Select the Properties tab.
                Activate the Flex Body check box.
Figure 1. Flex Body Option - For Abaqus: Use the .inp file.
 - For ADAMS: Use the H3D file.
 - For MotionSolve: Use the H3D file.
                Use the Invariants, Nodes, and
                        Modes buttons to set the properties.
                Note: You can set a flexbody tolerance through MDL and the user interface. When the magnitude between the flexbody node and corresponding MDL point exceeds this tolerance, MotionView automatically inserts a dummy body to bridge the distance. If the difference is less than the tolerance, the entities are exported to ADAMS without a dummy body (unless explicitly requested).
