Generate Results and Reports
![](../../images/post_processing/mpdb_results_and_reporting_example.png)
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Position a dummy model using the Dummy Browser.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Seatbelt Browser to create a complete seatbelt system.
Use the Barrier Positioner tool to automatically get the impact barrier into position, based on the selected crash regulation.
Use the IP Impact tools to automatically calculate the instrument panel (IP) testing area according to the regulations FMVSS201 and ECE-R21, position the headform impactor, and export ready-to-run solver decks for all the selected impact locations.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
Use the Safety ribbon to access crash and safety post-processing tools.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
Allows you to perform basic math operations on one, two, or three curves at a time.
The duration macro allows you to calculate the continuous duration for one or more curves.
Contains curve filtering functions, including Butterworth, FIR, and a new SAE 1995 that are not available to regular HyperGraph users.
The Injury menu offers calculations for all known injury assessment tools.
convert to/from common unit sets.
Contains some functions that are not commonly used, such as simulating a bar chart or histogram.
Provides several functions to calculate running statistics, regressions, FFTs, etc.
The Vehicle Safety Tools preference file contains templates to plot IIHS front intrusion and IIHS side structure intrusion plots for Radioss and LS-DYNA files.
The Pedestrian Impact tool facilitates the post-processing of pedestrian analysis.
The Instrumental Panel tool facilitates the post-processing of the FMVSS201 and ECE-R21 analysis.
The Compare Time History diagnostic tool consists of two pages. On the first page, the input data files, such as plot, result, and FE files, are selected. Page two contains the data needed to compare the reference files and comparison files.
Allows you to transform vector results from a time history or animation result files according to a coordinate system defined by three nodes from the same result file.
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case, for Radioss and LS-DYNA output files.
