Find and Display Sets that Contain Nodes/Elements
Select either elements or nodes from the model and find the sets that are collected.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Create an assembly structure from a .csv file definition.
Use the Quick Set tool to create relevant elements that are masked to ease further selection/generation.
Use the Boolean Operations tool to list elements and create new sets.
